Sprint rep suggests rooting phone OK
My front camera warper and my epic was rooted at the time. To be safe I odin back, created a second google account (so if they were nosy they wouldn't see my purchesd apps like TB.) They replaced the whole sccreen and I went home and re rooted then got back in my main google acct and reflashed. :) id just be safe and adin before I need repairs.
Sent from my Epic 4g using TapaTalk
Wow, Duby...done any time? Sounds like you a little bit paranoid. I think you'd probably be ok rooted or not, but if the phone works, probably an ODIN back to stock would be best since that's the first thing they will try to do is factory wipe and reset then restore. :)
No I just didn't want to run the risk and I'm thankful I did what I did bc they even asked for my google password. They said they needed it just in case they had to save my contacts or something if they had to replace the whole device. Id rather be careful and not caught then careless and void my insurance. Like ppl have said. Not ever sprint place runs the same way. Some don't care, some make a note ur rooted and some say no all together. :)
BobCat6767
