Sprint Update to Froyo Canceled...
Status
Not open for further replies.
Hmmm let's see Froyo = phone broken, Eclair = phone working properly You decide...
Hmm you must have some bad luck or something cause i manually updated and don't have any problems at all.
Sent from my SPH-D700 using Tapatalk
We aren't unlucky, you are lucky. From what sprint has said, there were more unsuccessful upgrades than successful. The poll on this site may not indicate this but you need to realize, the people on this site are not the majority of people getting this update.
Sent from my Epic using Tapatalk
No problems at all is indeed rare. My upgrade is better than average but it's not perfect.
Well I pulled the trigger last night and upgraded to EB13 via update.zip and for what it is worth, I wish I hadn't upgraded - at least on how I use my phone. The upgrade went fine and with a little tweaking everything works as perfect as can be except in no particular order:
1) display rotation is slow when in an app - approx 3 sec lag which can be fixed via terminal emulator - it can be fixed via calibration using Terminal Emulator from the Market Place, and you must have root, I used one click root v2.5.5 - it now works as it should! :D
2) Gallery is very slow to display, but quickens up if you load it one time in the cache, but if you reboot or change batteries (you are essentially rebooting when you do that) - it is painfully slow again - - it can be fixed via calibration using Terminal Emulator from the Market Place, and you must have root, I used one click root v2.5.5 - it now works as it should! :D
3) overall system speed in my epic is about the same - my 2.1 tweaked with LP was very quick.
4a) froyo really hosed the camera action shot function as in it doesn't work - it can be fixed via calibration using Terminal Emulator from the Market Place, and you must have root, I used one click root v2.5.5 - it now works as it should! Although I didn't know that this would fix it, but it did for me. - my mistake sport mode doesn't work but action shot does :confused:
4b) video recording works, but recording is bad in low light, although you do have a nice keep led on when video recording, but I would say it terrible overall compared to eclaire 2.1 - calibration using Terminal Emulator from the Market Place, and you must have root, I used one click root v2.5.5 - did not help this problem. :'(
5) my battery life has always been good in 2.1, so I am not sure if the battery life is going to be better or worse in 2.2.1, so far it seems as good as 2.1 - seems to be better! :D
6) you can't root and unroot using z4root anymore - I am not sure if you root via "one click root" if you can simply un-root and if you do un-root will it wipe all your settings and bring you back to stock? If so, I see that as a major disadvantage! - well I used one click root v2.5.5 - I am rooted again! :D
7) you do get a nice feature of moving apps to card, but with over a hundred apps I had and all working perfectly, I still had 165mb left, so I was ok
8) my gps is no better or worse, with the exception that I no longer have a hard coded 30m/98.4ft bug - my gps was always good in locking a signal quickly - only thing good is now I can see the how close I am to being on the spot in feet rather than always seeing 30m/98.4ft
9) the new messaging app sucks imho, because if you or someone types a you a message over 140 characters? forgot the actual limit, then rather being able to see the remaing part right below, you have to click the more button to see the remaining part of it - one more click, one more lag! :(
10) fring needs an update because it is semi screwed up in froyo - but Qik now works real well now! :D
11) my SWIftp possibly needs an update because that totaly errors out in froyo :'(
12) Shootme screen capture doesn't work now either! - I used one click root v2.5.5 - it now works as it should! :D
Now I know I can go back to eclaire 2.1, but if I do , I have to spend hours tweaking my settings again, which isn't that enjoyable unless you just like fiddleling with your phone/mini computer all of the time. Me, once I have tweaked it, granted I might tweak a little more here and there, I like to use my phone/mini computer to do the things I enjoy, I mean why buy a car if you are always working on it but never drive it?
With the improvement fixes that I got via calibration using Terminal Emulator from the Market Place, and you must have root, I used one click root v2.5.5 - it now works as it should! :D I will now stay on froyo 2.2.1 as most everything that I need is fixed to my satisfaction.
Bottom line for me, it took a lot of fiddleling after the upgrade, but now it is one step closer to how my eclaire 2.1 was; tweaked and nice but with a few extra nice touches from froyo and root - I am finally happy with the upgrade - too bad it took so much fiddling to make it right. :'(
Whew, I usually never rant this long, but maybe this will help those that are on the fence on upgrading. The above statements are only my opinion - good luck to all in your descison - maybe it is not all bad :-\
Mostly Fixed and running Good!!! :D:D:D
What calibration fixed your camera?
I was wrong - it did not fix the "sport" selection from the "Scene mode", it was late and I got it confused with the "action shot" which does work from the "Shooting mode"
It was corrected, you probably didn't see it.
Status
TheGreatApe00
