Stable customizable ROM for Sensation
You may not always get all you want from one custom ROM but you can makeup with Add-Ons.
I'm actually using Android Revolution HD. Nice ROM. Doesn't have the Tweaks seeing like Bulletproof, but I got everything I needed from flashable zips.
Mike’s 3.0.4 appears interesting, can you post feedback should you update
I am on IC 2.4.0, very stable with excellent battery life and speed. 2.4.1 is out, your choice should you have the need.
Does the insertcoin ROM include the new kernal or would I have to flash one?
No it doesn't, some has mentioned both 0.9 & 0.1.0 works well with 2.3.5, others not so well. Since most of the developers including baad have suggested stock kernel till custom once are stable, I'm sticking to stock at the moment. BTW should you choose to flash your kernel, the good till is that you can always go back to stock. Good luck
HTC Sensation 4G
Just flashed 3.0.4, seems like an improvement over 3.0.3. Only been using it for a few minutes, but it seems a little faster and smoother. I also like the included app that allows overclock and governor selection.
Nice, I will check it out later, I wonder why most developer are not incorporating SENSE 3.5 on their ROMs, Coredroid sensation 2.3 with SENSE 3.5 is cool but the battery needs some tweak
Never found a change log for Sense 3.5 - what did HTC change from 3.0?
How is the battery life
Actually it is surprisingly good. I think it's due to the pre-set underclocking while the screen is off.
Reactions: wcoast
Currently having fun with COREDROID SENSATION v2.4, the 3D is wow! I’m using stock kernel and no issue at the moment
I used Revolution HD for a day but it didn't seem to give consistent battery level readings which was annoying me, even after i wiped battery stats. I am thinking of flashing LeeDroid, has anyone had experience with it?
Romanbb fixed the whatsapp force close on Bulletproof, if you want to give it another go.
Haven't, let us know how you like it if you end up flashing.
So far I am liking LeeDroid 3.0.0, it has better power menu selections (like booting into Recovery) and more options on the Quick Settings pull down menu, which I think is similar to Bulletproof. Also includes a custom boot animation, CRT screen animations, and Titanium Backup - all of which are nice touches and additions i appreciate. I don't like having to flash additional zips if i don't have to.
I've been using LeeDroid since 2.2.
It's an excellent ROM. Very stable. He issued his first Kernel last night. That's a little wonky still. Caused a bunch of issues for me teh first time I tried it. I'm reflashing now. Will let you all know soon what I find.
gocoronago2021
