Stock or different launcher, root or not
I'm new to android as well and I don't fully understand the point of a different launcher. I installed the Google now launcher and other than giving me a dedicated Google now page and additional wallpaper, I don't see the difference. Am I missing something?
Not exactly. Let's see...
A replacement launcher allows you to tweak a lot of things. Many things can be perceived as minor to a person just starting out but for others (like myself) it's the culmination of all these minor things.
Whether it's adjusting the screen transitions or the app drawer style... maybe adding more rows and/columns to your home screens. Using themes for said launchers
Best suggestion is load an app called home switcher then load and try out several launchers. Experiment with them then try others. You may decide you like stock better who knows but it's about the options my friend.
I'm glad the Google now launcher was updated to suppose the G3 this past week. I downloaded it as soon as I could. The stock launcher for the G3 was garbage.
Why would you download an app to switch launchers when you can toggle between them all you want in the settings panel?
Sure you can do it that way too.
I use home switcher because...
Let's say Adw.ex launcher is my daily driver but I want to try something new like Apex. I put home switcher on both home screens during setup. Only to quickly flip flop back and forth
I came from several years of Nexus devices only....was a little dissatisfied with the G3 but it has a lot of potential. Root+Xposed+G3 tweakbox and titanium to freeze some useless apps and its running beautifully. I also get a camera that puts the Nexus 5 to shame which is a big plus for me. This is coming from someone who hasn't rooted android anything since my Galaxy S2 Skyrocket.
I would love a AOSP Rom like CM or PA BUT I am guessing that would break a lot of camera functionality.
You understand that it's right under the home screen in the settings menu, right? Why would you add an extra app for that? I could see if you changed launchers many times a day but....
Yes I understand very well and I still like home switcher.
To each their own is the moral of this story
For me the most compelling reason to use Nova Launcher over the stock LG launcher is so I can change the look of the icons.
The least attractive part of Android to me is the stock icons and how they're all shaped differently. Some are circles, some are squares, some are cut-outs of odd shapes (phone, Dropbox, etc.).
Nova (and other third-party launchers) let you use cool themed icons. Really classes up the phone look, to me.
For example, right now I'm using Cryten.
The stock launcher allows for this.
Been switching between stock(really good), GEL(need I say more?) and the Nokia X Launcher (super clean) surprisingly leaning towards X
I used to root but since nova launcher I really haven't had the need to. With Nova I can basically have a customizable stock android. Experience which for me is perfect
If you hold down the icon like your moving it but don't actually move it, a little edit symbol appears to the top right of the app and it allows you to change icons.
Sent from my VZW LG G3 (tapatalk)
Does anyone know if our purchased icon packs like stark etc will work in the stock launcher
Sent from my LG-D850 using Tapatalk
Unless there's a way to export them to a jpg or similar file, I haven't find a way
Thanks! Didn't know that. But is there a way to change them all at once to match a downloaded theme, like you can in Nova?
An apk is basically just a zip file. Download the icon pack, rename or open with zip app, and put the icons in a folder to use with stock launcher.
The ONLY reason that I rooted my Galaxy S4 GPE was to have the ability to write to the SD Card. Now that I have the One Plus One and it's 64GB of internal storage, I don't need to write to an SD card......and the OPO doesn't have an SD slot, lol.
TheGreatApe00
