Straight Talk APN Settings for Internet and MMS for At&T Samsung Galaxy SII Skyrocket
Tmobile is very spotty in my area as well. You may want to check AT&T 's coverage in your area. If AT&T has good coverage, Switching to Net10 might be the best thing for you unless your phone is locked to Tmobile.
I have tried all the settings on here and nothing works. the internet will work with the Straight Talk setting that they gave me but can't send nor receive picture message. Please help!!!
Re: Straight Talk APN Settings for Internet and MMS for At&T Samsung Galaxy SII Skyrocket
****mms proxy should be 66.209.11.33
- - - Updated - - -
I have a samsung galaxy exhibit 4g phone running android.i converted it to ST but now my internet is not working and i tried using the info in here to change my APN but it disappear and I cant change it to another one.can somebody pls help me?
My newest settings are the same as my last settings post, Except APN type is not set. I guess this change was needed after I updated to Jellybean 4.1.2
thank you very much, i've been trying to get connected to the internet without using wifi for about a week now, this article helped me fix my problem :)
check your spelling of tracfone ( not trackfone) also I you cant get picture mail type a ( * ) under APN type
add a ( * ) to APN type if you cant recive pictures.... also make sure that you type tracfone and not trackfone under proxy
I tried to change my apn on my straight talk galaxy s2 with a at&t sims card in it its all grey letters and stuff please help....
I have a Samsung Captivate what APN do I need to use to get this to run for straight talk?
Here's mine.
APN: att.mvno
Proxy: not set
Port: not set
User name: not set
Password : not set
Server: not set
MMSC: http://mmsc.cingular.com
MMS proxy: mms3.tracfone.com
MMS port: 80
MCC:310
MNC: 410
Authentication type: none
APN type: Internet+ mms
Bearer: Unspecified
My data has never worked this good, ever! (about 9 months)
Good Luck!
These settings gave me everything except i still cannot send/receive pictures ;(
I can't seem to access my APN settings, they are all grayed out or locked. This all happen when I updated my phone from Ice-cream to Jellybean 4.1.2. Help!
I have two choices, ATT phone (phone), or ATT WAP (wap.cingular). No matter which one I chose, when I hit edit, everything is grayed out, and can't be changed? Near the bottom is a check-box, "Enable/disable APN, its checked, and says APN enabled.
new APN settings for ST ATT sim on your renewal date you lose data. Enter this apn to get data back.
Support | Straight Talk
new settings
Field Settings
Name
straight talk
APN
tfdata
Port
80
MMSC
http://mms-tf.net
MMS Proxy
mms3.tracfone.com
MMS Port
80
Thank you. I was trying to find the settings for my i537 (s4 active) to work on straight talk and changing to a combination with these settings worked. in the end i ended up with:
apn: tfdata
proxy: proxy.mvno.tracfone.com
port: 80
user name: not set
password: not set
server: not set
mmsc: http://mms-tf.net
mms proxy: mms3.tracfone.com
mms port: 80
mcc: 310
mnc: 410
authentication: none
apn type: not set
apn protocol: ipv4
apn roaming protocol: ipv4
apn enabled
bearer: unspecified
Hello Everyone.
I have gone through every set of settings posted on this thread, and the only set that gives me some what success are the settings posted above by sweetride. With these settings i am able to send/receive mobile data but can't send/receive picture messages. I get the download failed error and the picture messages i send are never received.
Can anyone please post settings that have been confirmed to be working for both mobile data and MMS for using a Samsung Galaxy S2 Skyrocket with an AT&T sim from StraightTalk?
Thanks in advance!
These are the AT&T, Straight Talk settings for my Samsung Galaxy S2 Skyrocket (i727) in Louisville, Ky. Running Android 4.1.2 (Jellybean)
APN: att.mvno
Proxy: not set
Port: not set
User name: not set
Password : not set
Server: not set
MMS port: 80
MCC:310
MNC: 410
APN type: not set
APN protocol : IPv4 (shaded in gray)
Enable/disable APN : checked (shaded in gray)
Bearer: Unspecified
Good Luck!
So exeactly where to i enter this stuff. I cant convince my phone to let me put anything in for the setting (APN).
Hi Carol. On my Skyrocket the APNs are located at:
Settings > (Wireless & Networks) More... > Mobile Networks > Access Point Names
I am going to try this onc my phone decides to show me the APN screen again. I have a no name Mini7100 with Straighttalk At&T SIM card.
Well this is a bit embarrassing, but for those with MMS problems, try using an SMS app such as Go SMS. It works.
Hopluikla
