Straight Talk APN Settings for Internet and MMS for At&T Samsung Galaxy SII Skyrocket
The boyfriend had a Straight Talk GS2 which finally bit the dust yesterday. He severely cracked his screen and it kept working for months, but yesterday he dropped it at work and the screen no longer works. I borrowed an ATT Samsung Infuse from a friend, and put boyfriend's sim card in it. Calls and texts worked, but no data. Using your Setup 3, everything appears to work now. It's not even a BYOP sim card, it's the one that came with his phone. I'm super happy it worked, as now he can have a phone until we can afford another one. Thanks so much for your help.
Re: Straight Talk APN Settings for Internet and MMS for At&T Samsung Galaxy SII Skyrocket
Hello, im new here. I have looked everywhere for an answer to fix my mms to send and receive picture message. Until I stumbled upon the answer here for me...what really worked was when I saw this in a set up someone had posted. And soon as I did my picture message was working. Everyone please make sure you check your "USE PACKET DATA" is checked.
- - - Updated - - -
APN: att.mvno
Proxy: not set
Port: not set
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS Port: 80
APN Type: default,supl,mms,hipri
Could not send or recieve pics with my phone until a few minutes ago when I put in these settings in my Galaxy S2 Skyrocket. Hope this helps
WOW! after days of trying every apn under the sun this worked, woo hoo! thanks! a mill, if you got s2 skyrocket AT&T and problems with pics chomp sms does the trick just put these settings in 1st: name: st, apn:tfdata, port:80, mmsc:http://mms-tf.net, mms proxy:mms3.tracfone.com, mms port: 80 thats it nothing else just power off then back on. in chomp go to settings then sms&mms network, check sms delivery,uncheck tmobile, check activate mobile data. thats it!, give a holler!
I know this is an old post but wanted to post a thank you to Cassandra as these settings worked pervectly in my galaxy s4. THANY YOU!
Thank you sooooooo much!!!! Finally I can use my data and mms after changed my phone more than 2 months!!!! >0<
I recently purchased a Samsung Galaxy S4 Active. It's an unlocked AT&T phone. I have Straight Talk service. I am not able to receive pics or receive 'group' texts. I have tried MANY different APN settings and can't find one that works...anyone have some insight!
Thanks
Melissa
I have a Samsung Galaxy S2 Skyrocket (ATT) with Straight Talk.
Everything functioned fine except for receiving multimedia texts and group texts. I could not fix this with any APN settings.
I installed a messaging app called Handcent SMS, and now I don't have any issues receiving texts. Hope this app can help somebody else like me...
Re: Straight Talk APN Settings for Internet and MMS for At&T Samsung Galaxy SIII
Thanks for the tip Christie1969
I Downloaded GO SMS Pro and my AT&T Samsung Galaxy S2 Skyrocket works great now.
I can finally send and receive picture messages!
Not quite sure why the people at straight talk wouldn't recommend this????
Can't thank you enough for the tip!
I am in desperate need of mine working.. every time I change anything either text, or pics, or 4 g quits working, The only thing not working is I can not get mms messages to come through. any help would be greatly appreciated! Kristin
I need the APN settings for a Samsung Galaxy S3 mini using AT&T on Straight Talk. New phone from Samsung. So far everything works except for MMS download to phone fails. Thanks
Google the settings and get them directly from straight talk site. I did this and had to clear some of the fields other sites had me put in. Had to restart phone after proper settings. Just did it with wife's phone samsung galaxy s3. And mine and send and receive mms perfect now. It onlu took me 25 days of being with straight talk to get it right.
This worked on my Galaxy Note II - AT&T unlocked with Straight Talk AT&T Sim card. Thanks!!!
APN settings for android users BYOP ssStraight Talk AT&T sim
Im using a unlocked clone GS4 and data, SMS, MMS are all working. I used the APN settings from ST website and everything worked except MMS send or receive. I've played with all sorts of settings for quite a while before finally finding that these work.
APN: tfdata
APN type: default, mms
Proxy: Not set
Port: 80
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 66.209.11.33
MMS port: 80
MCC: 310
MNC: 410
Autentication type: None
APN protocol: IPv4
Apn roaming protocol: IPv4
Downloading the GO SMS PRO is the only thing that has worked for me!! THANK U THANK U THANK U!!!!
odigon
