Question Strange issue with Android system battery consumption
  • Thread starter Thread starter Deleted member 3205197
  • Start date Start date
D
Hello there. According to my battery usage figures, the time of usage of Android system since last full charge is more then the time from last full charge itself. For example, the last charge was 9 hours ago, the usage of Android system is 2 days. If I go into details, it shows 2 days in total, 9 hrs background. Is there an explanation for this odd thing?
I have Vivo V series, a bit more then 3 y.o.
I also have some apps duplicated, the topic was discussed here for some time ago, but I still don’t understand why it happened and if this is normal. Google Play services, Google services framework, Chrome, Settings and also Android System are double. Unfortunately I can’t delete duplicates, for example with Android system the doubled appears only when I go to Permissions (it has permission to my Contacts), and there is no way to forbid permission or delete it. I don’t know if the things are connected with this strange time of usage since charge.
Would appreciate any help and advice!
witnessloc24
