Stuck between a rock and a hard place
Christopher Adams
long story short i am getting the same error and it is throwing it into a endless loop until i took the battery out and did the same thing i did when i rooted it with odin and then it started back up fine that's where my problem lies i used goomanager to install twrp and then when i saw that i still had stock recovery i figured something went wrong and installed rom manager and flashed it for a recovery but when it went to recovery it did the endless loop and when i got the phone back up it said i had two recovery's installed so i am assuming that is what is causing it and need to figure out how to remove one or even both of them to try again i have tried hard reset but when it goes to recovery it happens again i really could use someones help any help is greatly appreciated!
on a side note i tried changing the services files for the free wifi teher and it gets stuck on the yellow sprint screen and i am currently trying to download the stock rom to see if that fixes it through odin.
jochu
