Stuck in bootloader with no OS, Cant access recovery cause bootloader is locked. HELP!!!!
sunnyfly
6
I installed the Android Revolution HD One 81.0 ROM onto my phone everything was a success but when it was going to reboot it said that Superuser was not installed. It asked me if I wanted to install superuser and I said yes but for some reason it didnt take me back to recovery to allow and istall superuser and it just rebooted. After that it stayed in the boot up screen for the longest and so I restarted and the same thing happened over and over again. I was able to bet back into recovery to re install the ROM wbich I did and tried it all over sgain but the same thing happened. I went into recovery once again and installed superuser with no problem then when I tried to reboot it siad that there was no OS and if I was sure that I wanted to reboot.
Now Im stuck at the bootloader. No OS and for some reason relocked. I have tried the RUU but ghe pc doesn't recognize that the phone is connected. What can I do? Please help me!
Andmyaxe90
