Stuck in Clockwork Recovery...HELP!
ManBearPig618
1,156
182
I was upgrading to the new version of codename. Booted into recovery, wiped data, wiped cache, wiped dalvik, then went to flash the rom.
now when I click install from sd it's just sitting on the android with a 3d shape spinning inside of it...
Edit - it also says "Back menu button disabled"....help!!!
Edit 2 - pressing the power button on any option just shows the Android....I'm stuck in clockwork recovery.
FALSE ALARM....just have to keep scrolling to get "back menu enabled"...in case this happens to anyone else.
Yeah that's a known bug in recovery.
If you get the unstable apps touch recovery addition you can have a work around for this issue .
And you swipe to move rather than scroll with the volume buttons
You are behind the curve with the stock recovery. That twitchy volume button scrolling is a drag.
The newer touch based recoveries are night and day better than stock.
We have 2 excellent options now.
Sent from my Galaxy Nexus
piikea
