Stuck in System Recovery <2e> manual mode
drewjohn
55
I was trying to fix my gps on 2.2 and flashed back to 2.1 than got the gps lock and flashed back to a saved rom by recovery.
now i'm stuck on a "Android system recovery <2e> Manual mode. It a screen with blue words and a pic of an exclamation piont. I try to apply update.zip but it says E:cant mount dev/block/vold/179:1
No such file of directory
E: cant mount SDCARD:update.zip
I can use odin because my computer wont recognize my phone. i downloaded the drivers over and over, used 2 different computers, and used 2 different USB cords.
HELP
HELP
I had no luck with the USB drivers from the non-Samsung links. However, here is the link to Samsung's site. I used this link they finally worked to unbrick my Epic after trying DK28. Make sure you click on "Software" to get to the actual drivers.
Samsung
The entire link that got me up and running again is here:
If you are unrooted and need help going back to DI18 Eclair - Android Forums
Good luck!
ok i had to jack with my phone alot. putting it in and out of download mode and pulling the usb in and out, but i finally got it to reconize my phone after a few hours. what a pain!!!
tired to do it all again today at work and same thing happened. luckily my work computer recognizes my phone better than both my home computers.
WTH is up with restoring my backups from clockwork. why do i keep getting stuck with the blue screen of death? I cleared the memory and everything.
I'm having the same issue here. Three finger boot gives me a *manual mode* with blue text and a choice to update from the SD that doesn't work because there isn't an update file on the SD. There should be a simple way to clear this, no?
Yes, that's exactly what it is. I went back to stock and lost Clockwork so it's a normal way for it to act. Rooting it with oneclick put it back. New at this and still finding my way around. Thanks.
when i first rooted my phone on 2.1, i got stuck on the stock recovery every time i booted to recover.y.
i actually had to hit apply update.zip from sd card to get into clockwork mod recovery.
anyways, i think the op forgot that you cant just flash back and forth between 2.1 and 2.2 roms. his post to me sounds like he was on 2.2 went to 2.1 and 2.2 again; which i dont think is possible because you need the kernel for 2.2 and stuff
i could be wrong cuz my android hacking is getting kinda rusty
Your correct you can't simply flash back and forth between 2.1 (Eclair) and 2.2 (Froyo) ROMs. You have to use Odin to return to Eclair from Froyo, then you have to use either Odin or an update.zip file to go from Eclair to Froyo. There is no simple "flashing" between OS's versions. Flashing can only be done on when staying on the same OS (Eclair or Froyo).
UMM.... I was fiddleing with the phone and got into voodooo recovory and im restoring but im not sure if it would work ..... '^^
HELP
well just flash back with odin without the sd card it works fine i had the same probelem ^^
I'm still stuck in that mode. Did you fix this problem and if so how so I can get back to a restore point I had on CM10. I can't stand AOKP Milestone 5. Can't even find my INTERNAL SD section.
satou hikari
