Stuck on Clockwork, help!
sasquatch080
10
Ok. So I'm running cym7 stable downloaded and flashed through rom manager. Everything works perfectly. Problem is that it wont let me flash back to RA recovery so I can switch to my omj rom backed up through RA recovery! It says it successfully flashed, but it didn't. Can someone point me in the right direction? Very much appreciated!
Have you tried flashing it from your bootloader?
Amon_RA 2.3 Here is the link to get it.
Just make sure you remove the (amon_ra 2.3). It needs to be exactly PC36IMG or it won't work. I just added that part so I could remember what it was for.
Did just that and for the record, only downloading apps from Rom Manager, but will not
use clockworkmod again. All you need is file manager from the market
So you can move files to SD card and rename if yo u have to.
Vector
