thantzinlin
- Aug 31, 2016
- 1
- 0
- 0
Re: Stuck on "Odin Mode" for no reason? Screen says "Downloading... Do not turn off target !!"
Me too
Me too
Go to Sammobile .com or samsung-updates .com, enter your model number to find your stock firmware, download it.I cannot do anything with my phone it just says downloading do not turn off target please can u help me
A beautiful person on another forum had the suggestion to "press the volume down key when it was supposed to be the volume up" when you get to the screen before this downloading loop sticks the phone, and it worked! My phone rebooted, and now is booting normally.
So if this happens to you, future reader, try taking the battery, sim, and sd card out, then put the battery back in (not the other two yet), and hold down-volume, power key, and home key at the same time. When the menu comes up that says to press volume up to continue (to Odin and the downloading loop) or press volume down to restart, press volume DOWN (yes, I know, I thought it would be a waste of time too). Then press the power key only to turn the phone on like normal.
Mine is now booting properly, even after a restart. After this is fixed, you can open it back up and replace the sim and sd card.![]()
THANKS MATE.
I've registered only to reply this guy
VOL DOWN+HOME+POWER BUTTON , at same time when device is turned off. then you'll see menu and push VOL DOWN button. That's All
You need to flash your stock firmware using Odin in PC.pls help. I have the same problem like the others here! I am stock on the bootloader screen. My screen looks like this:
Could not do normal boot.
ODIN MODE
PRODUCT NAME: SM-T33ONU
CURRENT BINARY: Samsung Official
SYSTEM STATUS: Custom
KNOX WARRANTY VOID: 0x0
QUALCOM SECUREBOOT: ENABLE (CSB)
RP SWREY: S1, T1, R1, A1, P1
SECURE DOWNLOAD : ENABLE
UDC START
This thing happened when i try to download TWRP. I flash the TWRP file .zip with flashify and after i reboot. And, when i reboot it shows this screen!
PLEAAAAAASE HELP:'(
Okay I have not seen anyone on here with my problem, so here it is. I have a Samsung Galaxy Notepro 12.2 Model SM-P900. I rooted it this evening after having it unrooted for the past 6mo. Things went fine, then I downloaded TWRP manager and then proceeded to install TWRP install so I would have that new boot menu so I could install a custom ROM. Watched the Youtube videos and read a few tutorials and thought I knew what I was doing.... NOPE! after installing the so called TWRP bootloader I ended up with the following
ODIN MODE
PRODUCT NAME: SM-P900
KNOX WARRANTY VOID: 1
AP SWREV: A1
Then a Green Android in the middle of the screen with message below it saying: "Downloading..." and below that "Don't turn off target!!"
Power + Down + Home gets me another screen that says Warning, A custom OS can cause problems in phone and installed applications.
If you want to download a custom OS, press the volume up key. Otherwise, press the volume down key to cancel.
Up gets me to what I described above...
Down takes me to a screen that looks like the Odin Mode, but it does not have all of that text. Just a green android in the middle of the screen. Below the Android is "Downloading..." below that is "Do not turn off target!!"
Can someone tell me how I get back into my table onto the home screen or have I bricked my device rendering it useless????
PLEASE HELP!!!!
Connect to Odin while in download mode(android screen with all the writing in the top left corner), flash your stock firmware.Did anyone help you? I have the SAME PROBLEM RIGHT NOW. Thanks!!
The most important thing to remember here is taking out battery for a couple of minutes, then SIM card and sd card. If you have built in battery and know how to remove then try as last option. Taking out SIM card and sd card should work. Press volume down (-) button, home button and power button. Next screen tells you to continue or Volume Down to continue. Make sure you press volume down - button and galaxy will reboot normally.
