supersu problems...please help!!
Galaxy Girl
4
I went through all the steps of rooting my phone but supersu wont open so i tried looking for knox to diable it and i cant find it. Can someone please help me.
Have you tried to update SuperSU through play store?
ANDROID...A New Digital Revolution Of Incredible Developers
Yes but it dont give me the option to update it. I even tried buying supersu pro but it wouldnt work.
You have to load super super thru your custom recovery. Save super super to your device then go into recovery using twrp or cwm recovery. Install super super that way and it will work. You will then be able to disable Knox because you will get a pop - up asking you if you want to do so. If you need more help let me know.
Terryujailey
