Superuser Problem
Elias1724
54
I'm trying to use Link2SD to move some apps to sd card since I was starting to run out of internal storage. Everytime I click on it it says It doesn't detect root access. I know I am rooted I have custom rom/kernal. I think the problem is superuser isn't sending the request to allow lLink2SD. I tried it on multiple root/superuser apps and it doesn't work. I also tried uninstalling updates on superuser and that doesn't work. Then I wantde to uninstall superuser itself and reinstall but I can't do that because the uninstall is greyed out in setting. Seem the only way to uninstall is Link2SD which I can't run without superuser. Any fix or way to uninstall superuser?
dont uninstall superuser... update the binary... go into the app, select link2sd, touch lower right hand corner icon to enable root permissions... close app and run link2sd again... if the root access prompt doesnt show up, you may need to reboot... and mabey wipe cache and dalvik?... just a guess as i dont use it...
Okay I fixed it I had to uninstall and inatall updates again
Sent from my VM670 using Tapatalk 2
Vector
