Swapping in a Spare Battery???
Yes the battery does come with a case that adds some girth to it. It's no longer slim by any stretch h of the imagination. However the one hand functionality of the device doesn't go away. I can do the same one handed operation as I could with the original battery. I can just do it three times longer. Well worth it to me as I am a habitual user.
Sent from my LG-E980 using Tapatalk 4
I did order the Caseology 2x 3200 batteries. I was going to wait for Anker, but that may be forever! My Anker batts for my Note 2 would read 100% for 2 hours after putting them in & would last me up to 6 days .... really, not a heavy user! Some of those batts that say 3500, 4500 or higher ... is bogus! Another note, some of those batteries that have Samsung Batteries are absolute junk!!! They would start out at 93% & some would even fall off like a rock (20 minutes) after 49%!
Beware & be careful .... I and others will report here after our findings .... too bad it will be a couple of weeks before they ship :(
Cheers, Jon
Cheers, Jon
In searching around, I found out that this battery won't have NFC compatibility, but for that price, and if it works 95% of the stock battery, and the charger charges the OEM battery, sounds like winner.. I just read some reviews on the Hyperion 2x3200 + Charger, and they said the batteriers work, not as strong as OEM, no NFC, and maybe about 90% as strong as the OEM. The charger takes about 7 to 8 hours to charge too. These Hyperions cost about $35 shipped, that is almost double to the Caseology with the 2 batteries and charger.. Think I will go with the Caseology for 2 reasons. Price is cheap, and they are just when I take trips, or really stuck out there.. Just like people always carry a spare tire, I am carrying a spare battery. :)
I need these
Sent from my SM-N900V using AC Forums mobile app
I am of the opinion that no phone has an adequate battery for all day use if you are a heavy user. That's why, in my humble opinion, I will always get a phone that has a removable battery!
Sent from my LG-E980 using AC Forums mobile app
I would be very impressed if you couldn't get all day use out of a Razr MAXX or a Note 2 / 3 ... I would considerer myself a VERY heavy phone user and I can always make it through one day on these devices.
Its true that not that many people post about changing battery. For me, the ability to change the battery at anytime is a plus. Its one of the top 2 or 3 reasons why I chose to buy into the Galaxy series.
It is an absolute must for me. As soon as I can get an OEM external charger and battery, I'm all over it.
Nothing like going from 0% battery to 100% in thirty seconds.
Purchased Oem battery charger kit today came with spare battery 49.99 at sprint store
Sent from my SM-N900P using AC Forums mobile app
Unless that phone has three times the battery life of the LG Optimus G Pro, I doubt I would make it through.
Scored a battery kit at sprint. Comes with a USB 3.0 charger but the power cord is 2.0. Will use the one that came with my phone instead. Battery case is a plus wasn't expecting that. And finally the extra battery to go with my 2 Acker batteries. I'm all set.
Beboomo
