Sync itunes library to Android
same here i keep getting this message when trying i used to have galaxy but then got a pixel 7 pro and I use rocket player any help i greatful i have uninstalled it and reinstalled it on both phone and pc as well as using usb connection
I'm glad you got it to work. Sure is a relief when you can finally get your music onto your device. I was pulling my hair out over the issue
For some reason, when I was searching for isyncr in the play store, there were 2 different ones. One worked and the other didn't. Are your USB drivers updated? Do you have more than one USB port? Maybe try using a different port
Good idea I'll check my driver's and dif ports
Adekanmbi
