System Info Widget Bug Reports
Doesn't look like you look at this anymore, but it would be nice if the free ram was reported correctly on the Droid Incredible 2. The number reported doesnt match either free or used from manage applications. Otherwise, its a nice widget.
Sorry to bother you with this, but on my CDMA galaxy nexus (stock, unrooted), I cannot get to the configuration screen for the widget. The widget works perfectly, but when I open the configuration screen it has a plack box with a smaller dark blue box on the bottom left corner. Is there any way to fix this?
Thanks.
tahirmehmoodkhokhar786
