System Info
bulldog812
I upgraded both of my T989's to 4.1.2, one of them worked fine the other is ok but is displaying system info across all screens. Does anyone know how to get rid of it?
I noticed that you have a USB attached to the device. Do you have USB debugging enabled as well as the option to show system info on the screen? Those are available under Settings>developer options. If you do, you might find it useful to turn USB debugging off, unless it's already deactivated or you're using a rooted ROM.
rjwalsh81
