T-Mobile Galaxy S4: Pick up calls and auto hang up problem.
Mihir Bhatt
4
Hi, i have a s4 and lately its been playing up, when i answer a call it immediately hangs up. I then have to call the person back.
I don't know what the problem is, i even googled it and couldn't find anything relevant. So i thought i write a thread on a forum.
Please can someone help me?
Thanks
Re: Pick up calls and auto hang up problem.
Thanks
Welcome to Android Central :)
How are you answering the calls? Regular swipe to answer or are you using the "AirCall Accept" option?
Sent from my Galaxy S4 running SlimKat 4.4.2
Thank you
Regular swipe
Does it hang up as soon as you answer or is it happening after you put it up to you ear?
I am having this same issue.. its really killing me that anything to do with this issue, there are literally no responses to.. ANYWHERE on these forums..if anyone knows what on earth is going on- can you PLEASE help?? I have even posted a new thread and gotten NO REPlys..
Its quite annerving when one cannot even use their "smartphone" to do simple phone tasks!!! im here trying to consult with the experts...is anyone willing to help??
Plz....HELP!!
I am also having this issue. I have a Verizon Galaxy S4. I've noticed that when my phone rings, it'll have the stock android incoming call screen (black screen with blue bar at the top, and circular icon to drag to answer the phone. After I drag to answer, it doesn't pick up but instead opens the touchwiz incoming call screen. Once I answer from that screen, the phone waits until I say, "Hello" and then hangs up immediately.
Is this similar to other people's experiences? I don't really know how to go about looking for help since it's such a strange situation.
Re: T-Mobile Galaxy S4: Pick up calls and auto hang up problem. WORKAROUND
*android s4 problem, call ends call is hanged up after being answered*
Scenario
Any Call triggers a CIRCLE type input. After swiping to the right the call does not begin immediately, instead, it opens up a HORIZONTAL BAR type of swipe. Instinctively, you will try to swipe right a second time to answer your call.
This causes the call to be answered, remain open for about 3 seconds, then hangup.
Problem
There is a conflict overlap with the phonecall UI. By accepting the call in two different UI's, the calls is terminated shortly after being picked up.
WORKAROUND:
When receiving an incoming call, answer it normally with the CIRCLE-type input by swiping right.
If the Touchwiz horizontal type screen is shown, ignore it, do not interact with it.
The call will take around 3 seconds to begin, but once it does, all will be ok and the auto-hangup will not take place.
CAUSE:
Unknown. But started to happen since June/July 2014.
Fix/solution
Not determined yet.
Is this still a problem for anyone else?
I can't answer any call with any setting.
Swiping hangs up.
Home key hangs up.
HELP
HasanAmmori
