T-mobile wifi calling - oli attached to incoming calls
Has anyone got any updates on a fix?
At one time, when I was within my 20 day return period, I was going to return my Note 3 because my voice would be garbled. Switch Wifi off, my voice clear as ice water. However, that was then, now my voice is clear all the way. Wifi stays on, only comes off when I go to use the hotspot. When I was at a Samsung both trying to find out how to transfer pics from my Note 3 to my Gear, the Samsung rep told me he was going to make sure all the updates were install. So, something must have happened. then.. I am with Tmobile..
When I receive a call on wifi calling, at the end of each number there is a ;oli=63 attached.
My calls are clear...but with the ;oli=63 attached to the incoming number, its not recognized by my contacts for caller ID.
I was curious... if there has been any update on a fix for this??
I received a security update sometime lastnight while I slept, telling me it's now under "current version: 0012" or something like that. So I turned off my wifi and turned it back on n realized it fixed the "somebody trying to access your network" notification. So I'm hoping this was a package deal that also fixed the "oli" issue as well. BTW, this issue was on all carriers, not just T-Mo.
I had that same receiving double texts problem with a previous phone. I don't remember the steps but it was due to a third party texting app I was using. Had to make it my default and stop the stock. The phone was basically receiving texts thru my stock and Go SMS app at the same time.
Late reply, just read that you were using Textra. Just installed on my new note 3. Not bad at all. Thanks for mentioning it in the convo.
update, I just uninstalled it. it doesn't read certain characters in a text from an i-phone. but the basic messaging software in the S3 and Note3 both read the characters fine. Also, cannot swipe to the right to make a call, or press message bubble and hold initiating a copy/cut function. Although it is there if the text bubble is hit once then look to the upper right for copy icons. continuing looking for another texting alternative.
Ltabboisi
