Tab 2 10.1 won't stay off
Re: Tab 2 10.1 stay off
Here is what works for me: (every time)
The only way to shut off my Tab 2 10.1 is:
1. Connect to charger or pc
2. Press and hold power button
3. While still holding down power, press Power Off
4. Still hold down power button depressed, press ok
5. Hold power button depressed till you see battery symbol on screen.
Only now you can let go of the power button and it will stay off
In other words: Do the usual just connect to charger and keep your finger on the power button throughout the process till it is off and battery symbol shows on screen
Good luck
NO SHUT OFF, AND NO UPDATE!!
It's been nearly a year since last post, when I *thought* my tablet would shut off. It does --- sometimes. I STILL have not been able to update my tablet, tho. I've tried Kies over and over and over.... no luck. The only think I have not tried is a factory reset or downloading another operating system.
how did you get a hold of Samsung?, do you have a number?..my Galaxy wont shut down, wont charge and it always says it has like 7 apps running when it first comes on(when it use to power down)...very irritating
None of the temp solutions for the power off and staying off of my P5113 were successful....EXCEPT ...changing the WIFI setting in advanced settings, disabling the wifi on when sleeping. The unit has been powering down and staying off since I changed that setting......Thankyou all.
my tab 7 wouldn't stay turned off (sleep)....what I did is go to apps and delete WOW SCREEN LOCK. There were 3 of them. Now my Tab 2 7.0 turns off like it should. I have os v4.2.2
Ever since I updated the firmware it turns back on right after I turn it off. Does this constantly!
Same exact issue here I'm so aggravated that samsung hasn't given an official fix... Did any 1 figure it out ...
Will someone post the official fix!? This is 2016! Some of these comments were from 4 years ago
Prince08900
