Tab S2, 8 inch battery change, what's a good battery?
ohmslaw
156
Well my battery is getting a little tired so I'd like to replace it. I have no problem doing the change myself. Problem is shopping. Looking around I see many batteries offered at various prices. I would like to hear if anyone has a brand that worked out for them. I see most companies offer install kits and I would want that.
Surprisingly, the majority of the batteries you'll find on Amazon are made by the same companies. I ordered two new batteries years ago for my ex-wife's Galaxy Tab 3, replacement types, as finding OEMs is nearly impossible. New Power 99 makes a solid battery, but they are quite pricy. I've bought other replacement type batteries, and they worked fine, as well.
Reviews will vary on any of them. Find one with a good warranty and return policy, and order up is the best advice regarding batteries.
Okay, they have batteries for T710 & T715, but not T713, which is the model of mine. Is there a difference between the T710, T715 & T713? Thank you.
