Taking notes
Hello
If I export a note from LN as pdf, where is it stored? All it asked was in which app to view the generated pdf file.
thanks
@dzigner: Where an exported PDF file is stored depends on your settings.
The default is that the PDF file is stored in the corresponding notebook directory, which is within the app directory. The default app directory follows an Android standard and is somewhat hidden, it is usually Android/data/com.acadoid.lecturenotes/files, starting in the root of the SD card; you can set a custom app directory in the app's storage settings (when doing that, note that it takes an app restart for such change to take effect and that your notebooks are not automatically moved to the new location, but the latter can be easily achieved by a backup of the notebooks board at the old location and a restore at the new location).
Besides that, you can also set a PDF directory in the app's storage settings, then all exported PDF files go there.
In case you prefer to share exported PDF instead of viewing it, change the options in the app's export settings.
Another update:
Got LN to sync via cloud services, using foldersync lite, but there is no instant sync, and even the advanced scheduled sync has not worked. I just set it up last night, so will wait until monday to really post about the foldersync app to use as cloud sync service.
thanks
mengatasipinkartudebitbni
