Tasker - Let's Contribute Profiles
Can someone help me set up a couple profiles. I have an App that I is for work which sends me a "notification" and I have 5 minutes to reply. The problem is if I am on a call, the phone doesn't make the notification noise, so I miss the reply time frame. Is there anyway to set it up so the notification tone plays while I'm on a call, and maybe make the screen flash or something too?
I created something that works for this, still working on a screen flash, gotta believe that there is an app for it. Flash notifications 2 should work outside of Tasker. I am thinking of alternating loading two images that will work for the flash portion without an app.
The Tasker profile did require
Autonotification installed as well. You can see the test profile screen shot. I set it up with Gmail as the app for test purposes only. It can also be configured to only run when you are on a call.
Finally been able to have Tasker to start the Bluetooth service, connect to my car, open Spotify and then begin playing whatever playlist is open...
Added a step to stop the activity monitoring service, and a audible notification that the bluetooth connection has been completed. No more guessing.
Great forum! I have been using tasker for about a month, and I am finding it really useful for many day to day tasks. However, I am having trouble with the location management. I hope someone out there can help me out.
First, a little background. I am self employed, which means I work out of an office a few days a week, out of my home some days, and I also have to go on the road. I also use public transport for office and home trips, and the car for away trips and other such as gym, mall, whatever.
So I have an away profile (for when in the city walking or public tranportation), which turns off wifi and gps, and does some battery saving features, like turning off the screen, limiting the cpu, ect..
Then, I have a near home profile, which turns on wifi, and removes some of the battery saving features, as when I am at home or near, I can more easily charge.
Furthermore, I have a wifi connected profile, which disables the passcode
Next, I have a car profile, which connects to bluetooth, turns on gps, music, waze, driving mode on, (next up, read text messages and whatsapp messages) and if I have it plugged in, keeps the screen on.
My problem arises when I leave the car, I can either be at away profile, or at home profile, and so the exit task, I think, needs to check last location and determine whether it is home or away and react accordingly. I think I need variables, but I don't know how to implement them. Any ideas??
Yep, variables are what you want. Here's how I'd do it:
Add an action to the exit task for your home profile, Variable Set (it's under, appropriately, Variables.) Under 'Name' put whatever you'd like, starting with the percentage symbol. I'll use %Gotincarat (got in car at). You can use any combination of letters and numbers you want, just make sure you have a capital in there (so you can refer to that variable in multiple tasks). Under 'to', put something that will act as a value for that variable. I'll put "home".
Do the same for your away profile, using the same variable (%Gotincarat) but a different value. I'll put "out".
Then go to the exit task for the car profile, and add two actions, each with an 'if'. One will have "If %Gotincarat ~ home" (If %Gotincarat matches home), and the action will be activating the away profile. The other will have "If %Gotincarat ~ out"), and the action will be activating the home profile.
(Actually, to allow for getting in the car away from home and getting out of it somewhere else away from home, I'd probably have "If %Gotincarat ~ away" trigger a scene with options for home profile and away profile, and maybe have it default to home after a minute or so, but that's a bigger can of worms.)
Can some one come up with this profile....?
Turn down brightness when I am @ home and make the brightness display to Auto when I am NOT @ home. I am guessing this would somehow be related to my home wifi, i tried setting it up but didn't work out for me !
Here's the simpler stuff I've got (in terms of what it does, not necessarily in terms of setup. I don't have anything I'd call super simple in terms of setup...)
Rotating Wallpaper
I keep a folder full of pictures of pretty landscapes on my phone. Every Monday at 5am, my phone chooses a random one and sets it as my wallpaper.
Dimmer
If light level is below 2, pulls up a homemade filter: a light grey non-blocking overlay that covers the whole screen. Removes this as an exit task.
WiFi Auto Off
If my phone is disconnected from WiFi for ten minutes, WiFi turns off, and I get a notification saying so with an action button to turn WiFi back on. The notification clears as an exit task.
[College City] Weather Popup and [Home City] Weather Popup
Between 6am and noon, when I unplug my phone, if I am connected to home or school wifi, my phone does the following for the appropriate location:
Grabs the accuweather forecast page, splits out the current temp and the high for the day, and displays both in a neat little popup with an exit button.
"Zip Charge"
If battery level is below 30, it's between 2pm and 10pm and I plug in my phone, I get a pop-up asking if I want a zip charge. If I tap that, the phone goes into "iso mode" (data off, WiFi off, screen minimum brightness) for a faster charge. (This is why I'm seriously considering not updating to Lollipop, unless it's changed to allow apps to turn off data.)
As an exit task, runs “End Iso” which turns on WiFi and data and kicks brightness back to normal.
Sleepless Popup
If Maps is opened I get a popup asking if I want "Keep Awake" or "Allow Sleep". The former turns the screen timeout to an hour, the latter does nothing. As an exit task the timeout is set to my usual 30 seconds.
Valentine's Day Gift...
(I have yet to test whether this works, since of course it's not Valentine's Day yet)
If my boyfriend texts my phone with a certain code (I'll let him choose this when I tell him about it), my phone will open a picture I made of half a heart, aligned to the left side of my screen.
If I text him with a certain code (already chosen, I just need to put the picture and an app with the task on his phone), his phone will open a picture of the other half, aligned to the right side of the screen.
Also when my phone connects to his phone's WiFi my half will pop up and my phone will send his the code that triggers his half. (This would get super annoying if we were together much, but we're long distance so we're rarely together for me to use his WiFi. This part is solely run by my phone anyway, so I can always delete it in Tasker if we get annoyed with it.)
[Service Project] Confirm
I'm part of a group that tutors local children once a week. Which of us go is decided early each week, and the driver for the week often forgets who is going and texts around the day of, asking.
So, on the appropriate day of the week, if I receive a text containing the name of the service project, my phone remembers the sender of the text in a variable, and triggers a menu asking "are you going to [service project]?" with options of yes and no.
Yes sends a text to the remembered contact, saying, "I am"
No sends a text to the remembered contact, saying "I'm not"
I have several more that I might post... they're more app-like and include a lot of tasks and scenes going back and forth between each other.
Hi to everyone!
New to phone and almost new to tasker, i use it for two months now and it is very helpful. I was searching for 2 tasks for a while but didnt find anything, and hope someone knows if is it possible.
1.Can i remap a button, e.g. long press back button to open an app.
2.Is there any way to double tap to sleep when on launcher homescreen?
Thanks in advance and very helpful topic!
WiFi Auto Off
"Zip Charge"
Can you share the Wifi auto off? Also i m on lollipop and you can turn off data with tasker with security settings plugin. :)
Interesting... that must be new to Secure Settings, last I heard that didn't work!
So for the WiFi Auto Off, you need two tasks, one for enter and one for exit. (I'll explain everything out, since this was my first task to use If and End If for flow control, and they're useful things people should know about.)
WiFi Auto Off (enter task)
Wait 10 minutes, IF %WIFII !~ *connection* (wait 10 minutes if the system variable WiFi Information does not match something including connection)
If WIFII !~ *connection* (this forces it to check the connection again after 10 minutes. The next two tasks will nest under the If and only happen if it is true, i.e. WiFi is still not connected.)
WiFi set off
Notify, title: WiFi Powered Off, text: WiFi disabled due to lack of connection, Permanent checked, under Actions you'll put the label Reactivate and have the button run WiFi set On (You can change the name, text, and label as you please. "permanent" keeps you from swiping the notification away, this is why you need the exit task. )
End If (this just tells Tasker you're done with the stuff you only want to happen "if" the If. I'm not sure if you need it here, since it's the end of the task, but it's a good habit to get into using it.)
WiFi Reactivate (exit task)
Notify Cancel, title: WiFi Powered Off. Make sure you uncheck Warn Not Exist! Otherwise every time your WiFi drops a connection and picks it back up, you'll get a flash telling you that a notification doesn't exist.
WiFi set On (logically you shouldn't need this, but without it my phone kept turning WiFi off again after I connected, so I just threw it in. Now that I know about the run log, I really should try to find out what actually goes on without this action.)
--ETA: I might have figured out what's going on. Add Stop WiFi Auto Off to this exit task as well. Tasks started by a profile aren't automatically stopped when the profile deactivates.
Your profile is simply:
State: WiFi connected (leave all the blanks blank, since you don't care which WiFi), and check "invert" (so it becomes WiFi Not Connected)
Enter task: WiFi Auto On
Exit task: WiFi Reactivate
Anyone who tries this, let me know how it works for you!
Thank you very much! It works perfectly!
I am using your profile to enable data and disable wifi when leaving home(or a place with wifi connection) and i also created a profile to check every 30 mins if there is an available wifi connection ,so as to disable data and enable wifi.
Here is a photo with the task if anyone is interested.
The first one is an if and there are end ifs after the down edge of the image.
The profile is time to check every 30 mins. :)
Wow: you're ahead of me on flow control! I haven't had the need to use Else If yet. :p
Sorry for bothering you again, but can you tell me how you did the zip charge? I cannot find a way to do a yes/no popup with actions...
Thanks!
I just have a single pop up task button that runs the "iso" task, because pop up task buttons can be dismissed with the back button. (And with the time context, the number of times I do dismiss it is very small.) If you wanted the buttons to say yes and no instead of task names, you'd want to make a scene and have the profile trigger that scene.
Btw, something to think about if you're using that one is whether you really need the 'End Iso' task. If elsewhere you have a task that runs when you unplug the phone, you could just incorporate the settings there instead.
While organizing last week I realized I already have an exit task for plugged in (it sets a variable for the phone being unplugged, needed for my rescue alarm). So I put my former "end Iso" stuff there. Ask for zip charge, Iso does its settings and then sets %Iso to "ran". The exit task for plugged in has an "If %Iso ~ ran" which undoes the Iso settings and then clears %Iso.
Hi all, just joined. I have been using Tasker for about a month with my Note 4 and loving it. I have a lot of profiles to share, but most are similar to what's on here. I also have a Scene which is a handy Grocery List app. Is there a separate thread for apps/scenes? Thanks.
Hello again,
i made a scene with images and it pop ups when i want but i cannot press anything..(I have made, when i tap the image to open an app.)It is just there, everywhere i go.When i tap on it , it is like it is not exist and i tap what is behind the scene(i think i confused this part :P). Any idea how to make scene buttons work?
Thanks
Edit: found it, i had chosen the scene as overlay and not as dialog.. little stupid, but 1st time using it :P
I don't delete it because someone may have the same problem.
Hello again!
I made a task to read me the caller when i have a call and i have the headphones plugged.. But it doesnt work :( ...
When i press the play button to test it , it works fine but when i have a call it doesnt work.. Any idea what to do to make it work?
Thank you in advance
arandheers' inspirational quotes
I made a tasker profile to show inspirational quotes every hour on home screen.
For this I made a text file containing more than 100 quotes, each seperated by "/" for seperating and identifying an individual quote.
Then picking up any quote randomly and pushing it to "Minimalistic Text" tasker plugin.
For displaying on screen I used "Minimalistic Text".
Step: 1
Create a text file with some quotes/jokes etc etc , each quote separated by a �/�
Example:
/Whatever the mind of man can conceive and believe, it can achieve. �Napoleon Hill
/Your time is limited, so don�t waste it living someone else�s life. �Steve Jobs
/Strive not to be a success, but rather to be of value. �Albert Einstein
/Two roads diverged in a wood, and I took the one less traveled by, and that has made all the difference. �Robert Frost
/The common question that gets asked in business is, �why?� That�s a good question, but an equally valid question is, �why not?� -Jeffrey Bezos
/You miss 100% of the shots you don�t take. �Wayne Gretzky
Step: 2
TASKER CONFIGURATION
Create the following variables in the Tab Var:
1. %Insptext
2. %Insprandom
3. %Insptextno
4. %Inspsugg
Create Profile: Insp Quotes
State: Battery Level [From:20 To:100 ]
Time: From 06:35 Till 22:35 // discarding sleep times
Enter: Insp Quotes
A1: Perform Task Name: Inspiration
A2: Wait [ MS:0 Seconds:0 Minutes:0 Hours:1 Days:0 ]
A3: Goto [ Type:Action Number Number:1 ]
Create Task Inspiration
A1: Read File [ File:/sdcard/Download/insp.txt To Var:%Insptext ]
A2: Variable Split [Name: %Insptext Splitter:/ ]
A3: Variable Set [ Name:%Insprandom To:%Insptext(#)]
A4: Variable Randomize [ Name:%Insptextno Min:1 Max:%Insprandom ]
A5: Variable Set [ Name:%Inspsugg To:%Insptext(%Insptextno)]
A6: Minimalistic Text [Configuration:insp = %Inspsugg ]
MINIMALISTIC TEXT CONFIGURATION
Choose a widget 4 x 2
Add Locale Variable - VARIABLE NAME: insp
Style: Default
Tap Behavior: Check the checkbox, Disable action on tap
You are done !!
I can't get arandheer's inspirational quotes (post#22) to work for me.
I set up Tasker and Minimalistic Text Widget exactly (I think) as detailed in arandheer's post, but the widget does not show anything.
When I checked the variables in Tasker, all have values in them except %Inspsugg. I thought this might be the issue.
Can anyone please see my screenshots of the Tasker profile, task, and variables as they appear in Tasker and advise ?
UPDATE 25 March 2015:
Nothing wrong with the steps provided by arandheer.
I removed the check for 'Do Maths' and 'Append' within Variable Set (they were ticked by default) and everything is now working perfectly.
Thanks arandheer for the detailed instructions and Daspoo for this helpful thread!
andiox
