Can't seem to get the Pattern Lock (Disable/Enable) to function consistently....
I have it set up to detect when connected to my home and work wifi. Have a task using Secure Setting Plugin to disable the Keyguard when connected to my wifi and enable it as an exit task.
Seem that it will work for a little while then suddenly stop working and the keyguard is back on even though i'm on wifi.
I tried installing Helper in Secure Settings but that didn't help.
Any ideas?
Any ideas?
