telus fascinate bricked
ok clockwork mod recovery v2.5.1.3-voodoo lagfix
current rom bionix-v-1.3.1
kernal is far as i know stock+voodoo-froyo-t959d-tlj3
thats what the file is called anyway thats the one i flashed with clockwork
im gonna start the adb stuff right now
hmmm yeah voodoo is not good to flash with odin but please make me those files either way
ill check out bionix see if there is a non voodoo version
thanks
ok i get this msg back dd is not recongized command iether internal nor external operable program or batch file
not word for word but same meaning
are you going into adb shell
it should look like this
adb shell
make sure your SD card is not mounted and does darkys rom come rooted, i imagine it does
from adb shell
do you see
# or $
if you see $ type SU
then look at your phone if it is asking you for super user permission, if it is hit allow
then
$ should turn into #
from adb shell
do you see
# or $
then
havent done darkys rom yet still in bionix but yes it is rooted will try su and see if that clears it up
cinemacritic
