telus fascinate bricked
ok so what a good stable rom to start with also i have noticed the stock gps is kinda slow if there is a rom with better gps that would be great
Can't answer that one for you, I am in Halifax and my gps does not work very well regadless of what rom (stock or custom) I used. :(
Glad you got the phone running did you have to use repartition?
I don't know of any roms for telus fascinate.. But please let us know if you find any. Maybe we can start a roms and hacks section for you guys
Sent from my SCH-I400 using Tapatalk
Boinix V and Darky's 9.3 work. Only thing is that you have to install the Telus Fascinate stock 2.2 JL3 kernel with clockwork recovery so that we can use Vibrant roms. I used personally used Boinix and Darkys. I currently running Darkys final version. Boinix was fine as well except I could not get the messaging ap to work. And that is a big no-no for me.
ok well i did it i installed a custom rom bionix-v-1.3.1 with voodoo and nothing went wrong im so happy lol
yeah had to repartition and click bootloader update but then was all good
the guide i posted that had the stock files was really good using that with any vibrant rom will work but as the op said make sure the rom has no bootloaders the one i installed worked great and had no bootloaders so i had nothing to remove though im not sure i like the rom no glitches or anything but i was really used the stock telus rom so gonna take a bit to adjust
ok great so next if i get a volunteer to work with me we can make odin flashable custom roms , then we can def make a hacks and roms section.
funny thing is the telus fascinate really isnt a fascinate at all it has almost the same rom as the vibrant or i should say kernal even the model numbers match cept the telus has a d at the end
if i have to go back to stock to help no problem lol and i have a working jig so i dont mind testing them out lol now that i am confident i can restore lol
you need to have time, need to have no fear of losing data or apps
no fear of bricking
able to use adb commands
have time to spend late nights
no fear of bricking
ok time i have not working right now losing data and apps no worries i already did that lol fear of bricking lol k did that too adb commands i know a couple and have the program i used to run dos all the time so should be pretty easy to get comfortable with it and im night hawk much to my gf distaste lol
so where do we start lol
after my boss leaves ill get back to you and ill tell you what we need to try
They are pretty much the same device. The reason it is called Telus Fascinate is because Bell already stole the vibrant moniker. Looking forward what you guys cook up.
are you on telus where did you get your darkys flash?
ok i need someone to do the following, get into adb shell copy each line individually below, right click in the command prompt and paste into the prompt and hit enter, wait for it to finish copying before attempting the proceeding command
dd if=/dev/block/bml1 of=/sdcard/1 bs=4096
dd if=/dev/block/bml2 of=/sdcard/2 bs=4096
dd if=/dev/block/bml3 of=/sdcard/3 bs=4096
dd if=/dev/block/bml4 of=/sdcard/4 bs=4096
dd if=/dev/block/bml5 of=/sdcard/5 bs=4096
dd if=/dev/block/bml6 of=/sdcard/6 bs=4096
dd if=/dev/block/bml7 of=/sdcard/7 bs=4096
dd if=/dev/block/bml8 of=/sdcard/8 bs=4096
dd if=/dev/block/bml9 of=/sdcard/9 bs=4096
dd if=/dev/block/bml10 of=/sdcard/10 bs=4096
dd if=/dev/block/bml11 of=/sdcard/11 bs=4096
dd if=/dev/block/bml12 of=/sdcard/12 bs=4096
dd if=/dev/block/stl1 of=/sdcard/1a bs=4096
dd if=/dev/block/stl2 of=/sdcard/2a bs=4096
dd if=/dev/block/stl3 of=/sdcard/3a bs=4096
dd if=/dev/block/stl4 of=/sdcard/4a bs=4096
dd if=/dev/block/stl5 of=/sdcard/5a bs=4096
dd if=/dev/block/stl6 of=/sdcard/6a bs=4096
dd if=/dev/block/stl7 of=/sdcard/7a bs=4096
dd if=/dev/block/stl8 of=/sdcard/8a bs=4096
dd if=/dev/block/stl9 of=/sdcard/9a bs=4096
dd if=/dev/block/stl10 of=/sdcard/10a bs=4096
dd if=/dev/block/stl11 of=/sdcard/11a bs=4096
dd if=/dev/block/stl12 of=/sdcard/12a bs=4096
after you are dont please move the files from your sd card onto your computer and zip them , upload them to something like megaupload and give me the link
also tell me what rom you are running, what kernel (if you flashed a non stock one) , if you have clockwork, what version of clockwork
baseband
and build. if you have questions please ask me
ZackS
