the N4 rattle sound - does yours have it? how do we get it fixed?
FOUND WHERE THIS SOUND COMES FROM!
I read on another post and said:
"Its the pin in the sim card tray! Hold the sim card release pin down in the hole and shake! No noise! Stop over think everything nothing wrong with the camera"
I JUST PLUGGED THE PIN IN THE SIM CARD TRAY!! and the noise is gone when I shake the phone with the pin inside there? so?
Nothing to worry about warranties since its a metallic noise that can not be deleted, the N4 that don't has the noise it's because maybe the compartment of the pin it's a bit more adjusted so it doesn't vibrate when you shake it!
:D heyyy thnk thnk thnk uuuu a lottt brother......... i was like crazy like hell about this sound....
i was concerned that where the hell this sound is cmng coz the phone's built quality is outstanding
nd then i tried putting a pin into the lock nd yesss thats b_t_h is causing the problem huh.......
thnks again
I think its the sim and/or tray making the very light rattle noise....but then again...."what's a battle???"
-ralph wiggum
Nazeer zaheen
