Motorola might be on a good track for growth. Even their new entry level products are getting good reviews and their new delivery model is getting good buzz. Now that it is essentially confirmed there is no sd slot on the Note 5, a chunk of the core Note audience could go to the new Moto X. Especially appealing to early upgrade folks.
Good things:
1. Same size display and resolution, plus view angles are apparently very good (for LCD).
2. SD slot
3. 32GB model will be at least $300 less
4. Front facing stereo speakers that apparently sound good
5. Camera is apparently good too
6. No carrier bloat
7. Unlocked
8. Custom cover options
9. Solid build- Should be less of a crack magnet than the Note 5 will likely be.
Concerns:
1. LCD display, so not as power efficient as OLED. Hopefully an IPS panel and not TFT (for LCD, IPS has better contrast and more power efficient).
2. Fixed battery powering the big 1440p LCD. Samsung has a fixed battery too, but bigger battery and OLED.
3. The consumer delivery model. Will it be adequate, or a bottleneck just using Best Buy and Motorola direct?
Added: The 808 verses the 7420 chipset is not a concern for me, since both are IMO fast enough. The 808 is faster overall than the 805 in the Note 4. I leave the Note 4 in power saving mode most of the time and do not even notice too many games impacted much.
Anandtech has a good summary review of the 808 performance in the G4- Another device that should gain customers due to Samsung's cardless move.
Good things:
2. SD slot
6. No carrier bloat
7. Unlocked
Concerns:
