The Sun Lite Betta
Update 1.42.
What's new:
- Added new detalization level 'UltraPC' (for Hi-end devices);
- Added control acceleration setting;
- Twicked time of day parameters (increased light period of day);
- Moving to final stage of NPC AI implementation;
- Other fixes and changes.
Google Play Market: The Sun Lite Betta
Update 1.43.
What's new:
- Added possibility to save and load at any time (look at palmtop);
- Added images of levels while loading;
- Added wind for UltraPC and Max settings;
- Removed damage from some damage zones;
- Added additional details (stones, grass)
- Other fixes.
Update 1.44.
What's new:
- Fixed problems with items after save/load (inventory, boxes, personal chest);
- Brought back run/walk button;
- Changed detectors behaviour;
- Changed anomaly zones behaviour;
- Changed radiation visual effect;
- Other changes;
*** Working on AI.
Update 1.45.
Saves made in 1.44 and before can corrupt quests. It's better to make clean installation (1.45).
What's new:
- Fixed errors with saves;
- Changed radiation effect;
- Fixed crushes on loading;
- Other changes.
*** Continue to work on AI system.
Version 1.46.0
What's new:
- Added slot for melee weapon;
- Added artifact (Higgs stone);
- Changed sensitivity of camera;
- Increased stats of food and water;
- Added device info panel;
- Fixed a lot of issues with save/load.
Version 1.46.4
What's new:
-Fixed problem with crashes while loading.
-Fixed issue with multiple pickups creation after updates.
-Added possiblity to inspect items in the inventory. It will be used in quests where you should read some documents or palmtops during quests.
AI system in The Sun. First attempts. Gameplay video.
For base assault we are using Sniper rifles and SMG.
For base assault we are using Assault rifle and shotgun.
Google Play Market: The Sun Lite Betta.
Report related with job that was made. Soon in update.
Time of day change. Sounds of the environment.
Enemy groups. NPC Behaviour.
Blockpost location. Beginning.
Location Desert plateau. Part 1: battle with mutants.
Desert plateau location. Part 2: battle with Corporation squad.
Abandoned bunker. Rifle for Hermit.
Moving back to Blockpost. New missions.
Old Base: hide of Hermit and rippers.
Slum: battle with marauders.
Update 1.5.
In order to get all changes, it's strongly recommended to begin new game.
What's new:
- Added AI system;
- Added new NPC (Allied and enemies);
- Changed Desert Plateau location;
- Changed AI system for monsters;
- Added birds (Crows, ravens);
- Added envirement sounds;
- Added new quests;
- Added new location;
- Changed auto aim;
- Increased light time of day;
- Temporary disabled mosters spawn (til the next update);
- You can criticaly damage enemies now if you hit it's weak spot;
- Bug fixes and other changes;
- Added new bugs.
* All will be optimized and improved in near future.
Version 1.5.4.
What's new:
- Fixed problem with boxes on locations;
- Improved spawn points behaviour. Now you can encounter someone on location that were cleared before;
- Fixed problem with incorrect ammo displaying after retrieving weapon;
- Fixed problem with NPC hit detection;
- Fixed problem with weapon jittering near NPC;
- Other changes.
Update 1.5.7.
What's new:
- Added random encounters;
- On random locations you with some chance items that you can't find on any seller;
- Fixed error with "Hermits hide" quest;
- Fixed bug with physics on some objects;
- "Blockpost" location has been changed a bit;
- Fixed bug with infinite loot;
- Optimization;
- Other minor changes.
Update 1.5.9.
What's new:
- In options menu has been added resolution slider. Now you can set your resolution up to native (not recomrnded), or lower if you have performance problems;
- Now NPC refreshes their money every 10 game hours;
- Added code locks;
- Added new quest.
Update 1.6.
What's new:
- Reduced damage taking from NPC (depends on weapon type);
- Added new random encounters where with some chance you can meet unique characters and merchants;
Update 1.6.4.
What's new:
- Fixed bug with duplicated interface;
- Now you can't get into random encounter in locations;
- Now state of the doors are maintened over (save/load);
- Other changes.
Version 1.6.5.
What's new:
- Added palmtop to topbar;
- Now at start of te game player will be equipped with pistol heal packs etc;
- Added decorations draw distance setting;
- Made optimisation (partial);
- Fixed some bugs;
- Made a lot of work for release locations.
Version 1.6.7.
What's new:
- Fixed bug with "Abandoned bunker" and "Mutants of desert plateau". Now they should finish correctly;
- While pointing to the NPC, looting body and trading you'll see name of the NPC and his fraction;
- While pointing to the pickup item you'll see additional info such as bullets count and is it quest item or not;
- Fixed Gyroscope;
- Removed acceleration setting;
- Working on release locations;
- Other changes and fixes.
Version 1.6.8.
What's new:
- Fixed bug with equipping items in dialogues;
- Now NPC should take some damage amount to become enemy;
- Changed view control;
- Other changes.
willarcanas
