(Theme) Apex 1.4.0
That error I believe is always on my screen in recovery. If the wipe wont fix see the sticky for the new sbf. Dl the file and rsd light. The flash takes about 10 minutes and your back up and running again.
Sent from my DROIDX using Tapatalk
I downloaded RSD lite and the sbf but haven't started the process yet -- I was trying to understand how RSD is used, I just install it on my comp ? or this is also goes on the SD card along with the SBF?
Sorry for hijacking your thread tnt, thank you very much for the help -- finally back up and running..can't wait to grab those blue zips :D
Im posting a quick how too apply the framework. Hope this helps some that had issues before. Still trying to get them zip files together but this will work. Video is uploading now and will be posted in the OP.
The framework is coming to the apex toolbox! Zips are ready but the tool box is awesome. Ill release zips for any changes. I may also finish the red framework tomorrow :)
Reactions: terpitude71
Framework has been added to the updated apex toolbox. The one posted is for the screen shot below. Ill post zips tonight for the others.
Zip files up for the theme in the OP. Both are the same with just different lock sliders. Enjoy!
Your on tb 1.0.6 right. Go to goodies, framework then its number 4.
Or I finally put together some zips posted on the main post :)
'talk' icon on notification bar.
Testing this theme. Installed from the toolbox. Looks like the 'Talk' icon when it shows up in the notification bar is a dark blob.:(
-bob
jesper76
