(Theme) ApexComb
***UPDATE***
I fixed the lock slider so now it wont show the stock one when you are in silent. I also added the honeycomb clock widget app that has the clock in blue and green. Also added the file to dl the honeycomb bee M logo replacement. The new file replaces the one in the OP. Enjoy!
***UPDATE***
Also I am putting together a boot animation, not final but what do you think.. Will share if there is interest...
http://forum.androidcentral.com/showthread.php?p=677183#post677183
***UPDATE***
Looks Great! Thanks a lot. :)
Stupid question, where to I put the icon images?
anywhere you want, those you download and then extract. once extracted you can move them anywhere, but they should still show up in a folder in your gallery. in adw you can long press to change custom icons in lpp you need to use folder organizer or an app like that...
Reactions: kentusmc
Well said. I use adw and they work great.
Sent from my DROIDX using Tapatalk
Reactions: kentusmc
I 2nd a Liberty version as that's how I roll :p, copied framework for you tnt but I'm not sure where I can upload it, should have renewed my dreamhost webspace :(
Anyone recommend a good place to up?
Click on the dl link in my post. Then click the megaupload Tex. Upload there. Then copy link and pm it to me :-)
Sent from my Xoom using Tapatalk
Reactions: kentusmc
I can but its not going to have it by 1%. It will be in 10%. Ill work on it later today.
Please don't change the battery meter in the liberty version, I prefer the regular battery you originally used :)
I wont. I like the stock battery too. Just got to give everyone what they want :)
Reactions: kentusmc
love the theme. What is the name of the bw clock? I can't find it. Thanks
That is a beautiful Widgets superclock skin, its called honeyclock. The skin wont work in home weather. I know this because I use the same clock ;)
CorpusChristi367
