(Theme) ApexComb
Added a new battery to the theme. Check out the screen shot.
DL Link - MEGAUPLOAD - The leading online storage and file delivery service
Reactions: kentusmc
I am having trouble installing this, are there any known problems? I would love to try it out.
Yes I am running the latest Apex
I am currently frozen while trying to install zip from SD
No known issues. Did you get it to work?
Sent from my DROIDX using Tapatalk
This theme is so great, thank you for your hard work =) Just flashed Apex today and so perfect. Thanks again!
I am having trouble geting the clock to show in the upper right hand coner next to the battery life...any help?
That can be found in the apex toolbox. It was down a few days ago but try this. Open terminal and type su then hit enter. Then type apextoolbox then enter. I think the server is down as I can't get in. The option to add or delete the clock is in the box.
Ok i tried that and it says it can't be found...so what i did was i flashed with the new battery theme and i have extracted the icons and wallpapers to my sd card...
and just to be clear you are refereing to terminal emulator?
Yup the box must be down. The dev server get pounded from the tool box and has been trying to get things fixed. Ill post when he gets them up and running.
FAB reported Toolbox server back on line today, so try the script again you should be good.
andiox
