[THEME][PORT]Ice Cream Moment Ported to Slider
Great theme I love it.
The only "bugs" I have seen are that on the homescreen (At least with launcher pro) and you go to the advanced menu the search glass has a light grey/white background instead of the dark grey.
When the phone has the keyboard out and then when you turn it on the lock screen goes back to the usual slider lock (Stock android)
Also as you slide the slider the "Unlock" text is black and hard to see. (Might have meant to be this way I'm not sure)
Again great job love the theme.
The wifi gps and bluetooth for somereason you can see. As for the sound and rotation, idk why they're darker. The color scheme was made by team hydro. I haven't gotten around to changing the icon colors for them. Although it doesn't bother me much. You can still see the sound and rotation they're just a bit darker than the wifi gps and bluetooth.
Ill prolly end up changing all of the icons white while off. And have them ics blue while on. If anyone likes this idea just say so and I maybe do it tonight or later this week.
Sent from my LG Optimus Slider running Gelato 11 28/ Gingerkernel7.1. Theme:ICS
I've fixed a few bugs that people were complaining about.
The non-transparent search button,
the dark notification bar quick icons,
and made the pattern look like ICS's.
I'll make some more tweaks later.
Edit:
Fixed the notification bar from being distorted in landscape mode.
Here's version 1.2.4.
It's significantly bigger because I've had to add framework.jar.
Feel free to inform me of any other bugs that you've encountered.
Reactions: LeoLawliet
theres a glitch idk how to fix... it's the black text glitch... when you have a notification for some apps, and it only shows the message in grey...
It appears that when you're downloading, the font for whatever you're downloading is all black, which doesn't show up.
Awesome job! I gave up on doing much of anything with this phone, but bordom brought me back to it. Tonight I flashed Mobster ROM, this ICS Theme, Holo Launcher, and Link2SD. So far I'm really happy with this setup, it works good, looks great, and I managed to gain back over half of the internal space.
ali5505
