[THEME]SuperMinimalv1 for AospCMod & Namelessv1[5/6/11][Updated]
Am I the only one that doesn't have the widgets on notification bar? Also boot animation doesn't work either. I'm on nameless rom, followed instructions exactly, only thing I didn't do was the font. I also wiped cache and dalvik
The widgets in the notification bar is zdtools I believe. You can get it from the market.
Sent from my VM670 using Tapatalk
Flashed clockwork, flashed the zip, worked well. Boot animation is nice. Searched market for zdtools but that came up blank. Overall nice though.
I am missin the step of flashing the UOT though right? Even on Nameless.
If your on nameless you don't use the uot file. There are instructions for the nameless rom on the first page
loving the update,
thanks again mate!
ps:hope theme'd icons are coming sooooooooon!
your welcome man!
yea themed icons coming soon
if you have any suggestions to how i should theme them or add any existing icons like aelous hd or something let me know
im sooo confused. so i followed all the instructions. how do i get the six big icons in the front and the small little launcher???
and the gorgeous widget as well??
you did everything correctly, if you want those seperate icons, launcher and, widget i'll pm you the links,cause those are done with desktop visualizer and fancy widget pro, if you want them plz pm me.
Prince08900
