theme that doesn't consume my battery?
There isn't any instructions. How do I go about flashing this theme?
This should be a normal theme flash just like any other.
1. Download theme and place on sd card.
2. Boot into CWM (starting from device off, Press and Hold Volume Down+Camera+Power)
3. Wipe cache partition/advanced>dalvik cache X 3
4. Flash the theme
5. Reboot
Reactions: sprocket2107
To make sure you completely remove the old theme I would reflash the ROM/kernel and then flash the new theme. Why I say this is because with the varying modifications devs make to their themes something in a new theme may not "overwrite" what your old theme has so you will end up with bits and pieces of the old theme left behind.
Does anyone have a version of the old BionixBlack theme? Someone at the XDA link was offering to PM it to anyone who wanted it, but for the life of me I can't figure out my XDA login info. Just thought I'd check here first, before I go and possibly make another XDA account.
I had a copy of that until recently, I lost that and other old themes in a hard drive crash just recently.
edit: please don't pm ragnarokx anymore as I suggested, he no longer has any of his Epic files since he has moved to a different device. Thank you.
Reactions: CptDanger88
would this work with my clockwork 3.1 the purple one? and is this like the bionix theme update 2?
I'm not entirely sure. It didn't work for me, but it seems like I always have a lot of problems that most people don't, so I'm still unsure. I got a bootloop, so make sure you do a backup first. I was hoping someone else could tell me if it worked for them.
didnt work......its not just you. maybe something to do with clock work or something
The Burg0964
