[Themes] HoneycombS, Alpha7 and Orion *4/13/2011*
Lovin the Honeycomb theme for the CM7... if the dialer had the same feel as it does in the Honeycomb theme I would be rockin the Alpha 7. Love both tho.. awesome addition. :) Good Evil haha
haven't came up with a good idea for the dialer yet.....unfortunately....lol
Just realized that my camera doesn't zoom to 4x anymore on cm7.... fail. Not ur themes issue tho lmao
so i have thunder ROM 1.8.2 and i download this put it on the root of my sd card, booted into recovery, made a backup, cleared cache, flashed the theme, rebooted, and........boot loop. Any ideas why?
(After it wouldn't boot i went back into recovery and flashed my nandroid so right now im right back where i started from)
by the way i still use xionia .4 recovery
could u be more specific... what are u flashing?? TRom theme or the Alpha 7 or what? Cuz only the FIRST one is for TRom.. and u didnt have to clear anything......
I think you should do the same style just with the Alpha 7 Colors... I think it would be Rockin man... I really like it. I mean something better is great too but that would still be the shiz!
im on thunder rom and i was flashing the first honeycomb theme i thought that the only one to work with anything but cm7
Possibly a dirty flash??
Maybe just reflash it or download it again and reflash it... I honestly have never had an issue flashing a theme...
Maybe someone else knows
alphaextras.zip wont flash
help please, i cant get the alpha extras.zip to flash. it says not signed. am i doing something wrong?? thanks.
theme problem
in the theme Chooser I'm getting "theme is improperly compiled. please report tto the theme author"
im having this problem also. i installed first apk but cant install second because it says that its already installed. ???
I've had no problems. Correct me if I'm wrong.The second apk writes over the first one to allow it to run in theme chooser if I remember correctly.
I thought that was rite still learning lol. Btw the zip for the alpha extras isn't downloading correctly. Any ideas? When I download it from my phone it stops @ 9 %. I download it from the PC its empty.
Look in your theme Chooser how many does it say u have? I had an issue where it installed and it not showing but theme Chooser said like 1 of 5 and only 4 showing untill I scrolled through the themes slowly and it was a small spot in between themes.
bassey
