Themes & ROMs [Updated 8-02-12]
You ported it, but did you ask for permission?
Without permission, you can't post
Or without credits even.
Sent from my VM670 using Tapatalk 2
: edit never mind lurking sorry. I just got here from reading mrg's thread and now see what you mean.
Are you suggesting Martinez ported this theme but forgot to ask for permission from himself and give himself credit?
No. The roms. Democracy Rom and the HTX MIUI rom.
Don't worry. The first thing I did was ask for permission. Also, you being good at porting I want to ask you if you know how to fix wifi hotspot
Lol
My status bar is black?
why??
Edit: rebooted and now works! Thanks!
Its ok :p I flashed it with a low battery (20%) so I haven't used it much. Ill tell you how it is tomorrow :p
Is only native wifi hotspot not working, or all wifi hotspot(including third party apps and native) not working? It could be a kernel thing...
only native hotspot doesn't work. you can download wifi tether from the market and put it in ad-hoc or netd and it will work but putting it in softap won't work either. :(
Update: Updated Both HTX MIUI (Themes now fully work and ROM remained smooth!) & Democracy (Only one change really). I want to fix Hotspot on both ROMs before releasing updates though. Also plan on making a few adjustments to the LOZ Theme and I'm also working on a new theme. Anyone wants to help out with the hotspot problem? Here's a logcat of me turning on hotspot.
Tethering Logcat - e67f6d07
Reactions: Badboytoast
You'd get more help and people to use the rom if you made a separate thread for each rom. I suggest that.
Crusher
