Things you've discovered on Note 8?
Just discovered the translate command detects the language. I was trying to translate what I thought was Spanish. Turns out it was Portuguese! The more I learn about this thing the more it enriches my life.
Portuguese is a mix of French and Spanish. easy mistake.
You have to enable that option: Settings > Advanced Features > Quick launch Camera
Once again, I'm aware of double tapping POWER button to quick launch camera, I'm talking about not having the ability to double tap HOME button to quick launch as in the video that I previously mentioned
One very welcome thing I've noticed is this Note 8 connects to the bluetooth in my car very, very fast. My Note 4 used to take 5 to 10 seconds to connect, longer than it took me to put on my seatbelt.
I wish I knew what the setting was for you. Mine defaulted with that ability. I'm with Verizon. I'll go see if I can find the setting. I suspect it's somewhere in the AOD settings.
Oh, sorry for misreading your post. As said by others, the home key double tap for the camera option has been taken away.
I like being able to train the phone to recongnize my voice. All I have to say is "OK Google" and my phone opens up. Of course it goes directly to the Google Assistant page but all you have to do is press the home screen button to fix it.
One press on home button (or in my case - where the button should be as I've got them invisible) from AOD screen, and phone opens to hs almost instantly using iris scan. Brilliant!
There are just SO MANY ways to get the Note 8 to open and yet iPhone users are high fiving each other over face recognition.
Dunno.jpg ...you have to remember, they have this little iWorld they live in where everything "iNew" is... NEW!
(Sorry, my bad - I had to... the devil made me do it? Yeah, that's the ticket!)
I have to go to bed earlier... when I stay up this late, all I seem to do is get myself in trouble!
It works on my verizon phone.
Do you have a setting to turn it on and off? If so, would you tell me the path to that setting? On mine, under Advanced Features, it gives me an option to for Quick Launch Camera, but only by way of the power button.
Adekanmbi
