Thinnest S4 Case?
I have gone through 3 of the Spigen Hybrid case frames so far. They tend to break at the bottom where the charger plugs in. The frame material is very thin at this point and it is where you constantly plug the charger in and if you plug or unplug even at the slightest angle it will break. Nice case but major design flaw! :(
+1 on the spigen ultra thin. It fits perfectly and tight and will never come loose unless you take it off yourself. I used the neo hybrid for a while and got sick of it. It would constantly come loose and made the phone really bulky. I have the shiny orange one and it looks really nice with white and still looks great after a year or use. I suggest using a glass screen protector with it to add extra protection.
kctraci1
