Third Party Launchers?
I paid for the full version a long time ago so I will reinstall it and give it a try. Cheers Javier.
When you install Nova it's possible that it won't stick as default launcher on the first try. This is normal with some OEMs and you just need to repeat the process (in both the phone and Nova settings) until it works. Also, MIUI is known for a very aggressive RAM and battery management. This means that there's a chance that it could kill some background processes, like your widgets in Nova, making them not to refresh properly. If this happens make sure those apps/widgets are not optimised in MIUI settings.
Hi Javier, I thought I would check with the Xiaomi Mi Community regarding this issue. The guru's on there suggested that I leave well alone as Nova will be very unreliable. I'm fairly happy with MIUI's stock launcher so I'll stick with that for now. Thanks for your help.
I guess I am one of the few that don't care for nova. I tried it a couple of times but always went back to Smart Launcher.
What is it that you don't care for in Nova or is it that Smart Launcher has a feature that Nova doesn't for you?
I have used Nova and Niagara, Hyperion and Microsoft. Currently I am using Smart Launcher as I like the categories in the app drawer and I like the arch layout for icons on my screen. Dynamic theming works well and it was simple to set up.
Reactions: BEaRebel
I paid for Nova a long time ago; got it on sale too. Always used it for the same reason as @Javier P does: gestures. double tap to sleep, with Nova, and double tap to wake that's integrated in the Pixel, and I hardly use my power button.
Yup, unfortunately that's the case with Xiaomi and third party launchers.
I actually purchased nova and gave it a good try a couple of times on different devices. I don't know what is available on it now but at the time, it did not have drawers, and the home screen looked like all the others with rows with limited customizing. It had a higher learning curve than smart launcher and more. I wanted something with a completely different look.
The thing that I like about Nova over other launchers is the backups. You can create endless creations/configurations and then back them up wherever you want so you can recall that one-off crazy configuration 2 years from now...if you want. I don't know of another launcher that allows that reliably.
I tried so many over the years just to check them out , Nova hands down .
To me that does sound crazy. Complicated, crazy, but some people like it.
App drawer is definitely available in Nova. In fact, one reason I liked Nova is because I could use a vertical app drawer. It is also possible to use all kinds of custom gestures in Nova: your mileage may vary there, since not everyone likes using gestures.
Reactions: mustang7757
My customization-obsessed self would love to have that as an option!
I have used Nova since my S4. I love the customizations and the backup. I wish Nova would support the Samsung Folds. I miss Nova on my Fold 3. I have tried all the Samsung customizations and they are ok, but they don't deliver what I liked about Nova.
Yeah I truly missed Nova on the foldable ...I had Fold 2 and 3 ...
I use Microsoft Launcher. Just wanted vertical scrolling on my 20fe. Samsung has an app for it but ms launcher seems nice and light compared to nova.
I really like Niagra for when I want a simpler screen (relatively) but I always end up going back to Nova VII.
khatunkhatunc
