Oathkeeper1212
- Aug 30, 2011
- 472
- 65
- 0
Well I still have the zip if you want it. And I have a root method for the gingerbread update.
Sent from my LG-P505 using Tapatalk
Rooting is not the issue. I was rooted about 10 minutes after installing the official update using LG's tool. I have even tried several roms with CWM. All of them that use the a .32 kernel/obb don't work because of the update(by don't work, i mean no data services and some no phone service). The ones that use a .35 kernel/nbb will boot looking real nice with Joban's no longer available .35 kernel but do not have data services. So to me the question is, do you like the roms available that use the .32 kernel/obb? Then don't upgrade. Otherwise, if you can have stock gingerbread and rooting take all of 5 minutes if that.
using the following site
Root LG Optimus One P500 on Android 2.3.3 Gingerbread
I have a question, are you all using the gingerbreak exploit through superoneclick or is there a better method?
so no emergency mode?
HELP i downloaded gingerbreak to my sd card and icant use open it any ideas?
