This isn't making sense?
Awesome glad you got it working correctly now.
As for the backup don't bother the backup/restore function does not work correctly in CWR yet. And if you do a restore it will brick the device. So you are better off not even making one so you don't by accident restore it and then really brick the device. Some have been saved and others have not been saved last I read on it.
As for the Calendar I can't really say myself but in reality it can't hurt it if you did install it.
I think you can now do backup/restores with the new inmuts. Here's the thread that says it's been fixed:
[RECOVERY][6-11-11]Clockwork Mod Recovery - xda-developers
Before I try, can anyone confirm that it works?
Read that more carefully Veregund it says somethine like... after the crossed out back/restore is listed it says: "Should no longer be an option you can see"
sorry i wish it was fixed too, heres hoping for the next release
tvgal
