Thrive problems, questions, and comments
Is there a way to enlarge a page, when on the internet? most times the text is fine, sometimes its small.
I needed to click on something out of a list and it was so small, it was hard to click on the right one.
Place your thumb and pointer finger close together in the center of the page; slowly move your thumb and finger apart and PRESTO! the text will become larger. :)
To make text smaller, do the opposite.
Reactions: nonie
This is true.
If you want to increase the default text size or set the default zoom to larger then from the browser, go to Settings (horizontal line icon at top right of the screen) > Advanced and then you will find the text and zoom options near the middle of the list.
Reactions: nonie
Hummingbirdhill, how are you liking Kaspersky? does it use up lots of your battery? saw on another site that it did.
I guess I will have to give it a try. Tried to download Lookout, but couldn't get it to work.
Also, if you "double-tap" on a webpage, especially in the area you are interested in reading, the webpage will zoom in and justify the text. You may have to slide the page left or right to center it, but it works extremely well.
Reactions: nonie
I've not noticed that it particularly uses more battery but when it's updating I can't do much else on my device. :(
Reactions: nonie
How often does it update?
Although I've not kept track of the update frequency, I think I read in Kaspersky's description that it updates weekly. Or maybe that's what I set it for. The software has been an annoyance to me since I activated it, but I figure I can put up with a free month. :)
Reactions: nonie
SeVeR
