Tmobile lollipop update is live!!!!!!
I got note edge a week back (from note 3). I exactly followed the same steps you mentioned to set it up. Am in love with this and not sure I can go back to something edge less.
Oh ok. Glad to hear that. Yeah I do that after every big update....android or iPhone. I install the update then I do a hard reset. Never has failed me. Been doing it that way for years. Never have issues with none of my phones. Yeah you shouldn't have to do a hard reset after an update but it is what it is lol.
Posted via my Samsung Galaxy Note 4
I am loving the update on my Note 4. I just had the best ever battery life on my phone. Two full days standby with two hours screen time. Of course I could have easily doubled that screen time and used the phone to where I had to charge it in one day. I do have more than one phone and my Note Edge is my take everywhere phone.
I never did a reset to factory or cache reset, just an upgrade on the Note 4.
View attachment 176950View attachment 176951
How did you get 2 days on battery stats to show up? I miss that from kit kat.
your phone is draining even at night, can be better !
Have you tried updating with Samsung Kies? Install the program on your computer and then start it. Connect your phone to the computer and it will prompt you that there is an update available. It took me less than five minutes to download the update and then it installed without and problems.
I tried that. It didn't work. My PC just sat there and nothing happened.
Could the phone being encrypted have something to do with this?
If you've not already tried, see if it works outside your vehicle. Occasionally I've found glass that has some kind of coating (probably for UV protection) that also interferes with GPS signals.
I found that one USB port on my PC doesn't work well with the Note 4, so I used a different port and that solved my issue.
Sucks the next version of Android, "M", will be out in a couple months and some haven't even gotten "L". Would be great to see Google change that process to be similar to how iOS is handled.
In principle, I agree. The option should at least be promptly available. But I suspect the impediment is less Google than the carriers trying to make sure--and rightly so!--that a release does not generate complaints with every other person who uses their phones.
For myself, I've always been a bit cautious about OS updates. I'd like to see how it works out. Let someone else find the bugs. ;)
soraplzzzzz
