[Tool]Cdma Wildfire S-off, Root & Cwm One Click/Script (Rc 1.0)
Re: Wildfire S-off, Root & Cwm One Click/Script (Beta)
For the above? Simmon had confirmed it worked last night. Pastbin the whole output.
Edit: Simmon just brought up something that may be the cause. Unistall htc sync if it is installed.
Does this method turn S-off and root the phone? Or does it just turn S-off?
Everytime I try and use the s off / root software and manual S off/ root method get the ? no img or wrong img? message on my phone. What do I do? I did everything like I was supposed to. :( please help me!
I keep getting the ?no img or wrong img? and it keeps saying it cant find the image and stuff. What is the solution to this problem?
Well the first on in the first poot will s-off but you will get a error on cwm. Also possibly not root. Where I posted that one script I made for a few other devices that simmon said works fine. So it will root the phone if that is all you want.
For the errors about the files on the card. You need to plug the phone in as charge only. Though as I said post the output or I can't help you. If the output is long paste it on pastebin with the link in your post.
I did! It's the files you are using to s-off my device....its not operable!!!
How am I suppose to help you if you won't help yourself? I did these to help you guys. If you don't want to help make it work I can't do a thing about it besides set and watch. I said give me the output of what isn't doing what ever. I left that stuff view-able so I could debug the script.
How ever I know for a fact the s-off process works and the 2nd script I posted will root perm root what ever rom you have on the phone. I am rewriting this script to be more user friendly and be a all in one tool like I just finished for the merge. So that will fix flashing cwm with the one in the first post. How ever it won't fix your issue.
By the way I don't like people with attitudes. Mainly when they refuse to do something I ask, yet still complain.
Edit: Actually are you gsm or cdma? As it sounds gsm. That or your goldcard isn't right if the manual way doesn't work.
the electrify app also failed to copy superuser and such, i took a screenshot as i think that would be better than me trying to type it out, thanks for any help:)
also it didnt root my device either
Ok weird as it has been confirmed by simmon and a few other people to work. [Tool] One Click Perm-Root & Busybox Installer • General Discussion • 2FastRoms If you are just wanting to try root. That is my latest version. Where there is two, try either of them and let me know what you get.
Instead of a screenshot, right click in the window. Go to mark, highlight everything, followed by right click and copy. Then paste the output into a new pastebin at pastebin.org. Then post the link.
Re: [Tool]Cdma Wildfire S-off, Root & Cwm One Click/Script (Rc 1.
Updated first post with new script. With the new script follow the directions. It will s-off, permroot, install busbox and my lastest cwm build for the cdma wildfire. Not the gsm wildfire cwm now. Thanks...
Reactions: mkm1126
Bump to the top for feedback...
I'm having trouble getting Simple Gold Card to work. I've tried this on two computers... when I go to format the SD card, I get a "Disk format utility" error prompt. So I tried to format in windows, then patch with the goldcard.img. I get yet another error and and the program closes.
I'm wondering if my SD card might be messed up?
I have a problem when I'm already in hboot phone shows "DIAG is jumping ..." and nothing further happens if you could help me?
I've run into a problem, when I'm in hboot it says that S is On. I don't know what I did wrong along the way. How do you turn S-off from the hboot screen?
it worked ON THE METRO PCS WILDFIRE S :DDDD
my sd card says goldcard now but when it finished i check to see if it worked and it did not its still s-on can anyone help me
HTC WILDFIRE metro pcs...runs 2.3.4
If you don't paste the output or say if you followed the directions I can not help you.
ok i followed the directions and i found out what i was doing wrong...but now my screen is on the clean s58 data and it says
keycard level:[255], not 0
unlock SECU_FLAG NG
how long do i have to wait? or do i unplug my phone and reboot it?
In step 6 i never got a prompt about installing drivers. What should I do?
Getting this error dont know what to do :S following steps to the letter
Btw I have my phone rooted I dont know if thats a problem it was with super one click
tryhomematch
