[Tool] One Click Perm-Root & Busybox Installer (Cdma & Gsm)
I figured it out before you had tried it. Even though zerg works and mounts as read and write. The nand lock is disabling read and write.
links are down 12/30 11:30 pm
Links are up 12/31 11 am
skinsfan go to android market and download superuser and titanium backup, also app2sd if your having memry issues
That isn't the first time I seen that now which is odd. As gsm seems to have the same issue. If you have experience with adb. Do the following:
Code:
adb shell
Code:
df
You should get a output of the partitions. Where if you can copy that here, I will look. How ever this is pretty odd and stupid. If you are indeed out of memory there will be no other builds for the wildfire s made more than likely. I could do up a script to remove one or two bloat apps to gain some space to run the tool.
I sure could use that script to remove a couple bloated apps i have tried several root methods and have gotten the same no memory error
i am also recieving a no memory error when installing the apps, i will uninstall apps and try again but doesnt seem like it will work
System rom: 275mb (17.6 MB free) Titanium Backup
how can i free up space???????
I'm also getting the memory error. I factory reset my phone as to have as much free space as possible... still the same error, a bunch of lines of "cannot copy/find etc" and "out of memory" stuff.
I've tried everything and I just cannot get this phone rooted. :/
You need to unlock via htc unlock to get root on the gsm variant. Or in better terms you need s-off or unlocked for root.
the download links wont work whats up with that i was really excited when i saw this cause ive been trying to s off and root my phone for 2 weeks now and am at a point where im stuck. i dont want to give up but i have no idea what to do. this would have been awesome if the links worked....
The link doesnt work plz help. i need to root the htc wildfire s it has like no internal memory i want to get rid of bloaware and i dont want link2sd or any of that. any advice for root? and bootloader unlock doesnt work
http://androidforums.com/wildfire-s-all-things-root/480954-guide-how-root-wildfire-s-s-finally.html
Just do the "Before you begin section" , Do step 1 and backup the phone then skip to 3A
On step 3A I just did "All other supported models" and got the unlock_code.bin and flash to your phone from the htcdev.com instructions, then poof unlocked bootloader. No need to do RUU since it's a pain to get setup.
godef
