Top bar not showing (Android 10 Beta)
  • Start date Start date
I posted this issue on the OnePlus community thread as it's a major bug.
Basically if you have the notch disabled and flash to Android 10 beta then you will no longer be able to re-enable the notch.
Ouch, weird bug. At least we know where the problem is. Thanks for chiming in.
I wonder if using an app like Nacho Notch could override that missing setting and get the status bar back. Or maybe make things worse. :)
I see. Thank you! I'll inform if they fix this bug recently.
Sara do you have a 3rd party launcher like Nova ?
Go to phone settings >apps and notifications >default apps>home app tap , what is your options there?
Oh, sorry. Didn't see your reply back then. No I don't have.
They fixed this and the notification slider (didn't turn from silent to ring mode when sliding the slider) this patch, OP7_O2_BETA_5. All good now. Haven't tried to hide the notch again
EDIT: forgot that it doesn't show anything when screenshotting but anyway the hotbar and notch shows now :D
Chris 4502
