top level shell gestures
NLyons
Is there a faq or list of gestures that apply to the top level window shell? I accidentally performed a gesture while cleaning dust off of my Froyo Epic 4G and now I can only intermittently replicate it.
The gesture I would loosely describe as a 'remember ribbon' shape (as in 'remember the troops' decal you see on the back of cars) that could also be described as a number '9' with two tails (descenders) and this was done in the vicinity of the top of the display.
The effect of the gesture is to open up a view showing all 7 possible home windows and it also lets you pick which one is your current home.
It makes me wonder what other gestures I am unaware of... anyone have a list of them?
Thx!
That gesture is new to Froyo update.
you do an opposite of pinch zoom
(that is, press screen using 2 fingers, then drag the fingers toward each other)
That will show all 7 screens in TouchWiz and also in Application screen.
While it's showing all 7 screens,
you can click one screen to go there directly, or
press back button, then you'll go back to normal screen.
Hope that helps...
Reactions: jrmitchell72
Staff online
bydasarinai
